Конфигурационные файлы FreeBsd-
Сообщение ROOT » 13 июл 2014, 23:41
 Содержание
 1) Конфигурация ядра
 2) Стартовый скрипт rc.conf
 3) Firewall IPFW
 4) Синхронизация времени по протоколу ntp
 5) Настройка разрешения имён
 6) Файл hosts
 7) PHP 5.5.14
 8) PhpMyAdmin 4.2.5
 9) Настройка клиента MySql
 10) UCARP
 11)ProFTPd
 12)
 13)
 14)
 15)
 16)
 17)
 /usr/src/sys/amd64/conf/SERGEY
cpu             HAMMER
ident   SERGEY
makeoptions     DEBUG=-g                        # Build kernel with gdb(1) debug symbols
makeoptions     WITH_CTF=1                      # Run ctfconvert(1) for DTrace support
options         SCHED_ULE                       # ULE scheduler
options         PREEMPTION                      # Enable kernel thread preemption
options         INET                            # InterNETworking
#options        INET6                           # IPv6 communications protocols
options         TCP_OFFLOAD                     # TCP offload
options         SCTP                            # Stream Control Transmission Protocol
options         FFS                                     # Berkeley Fast Filesystem
options         SOFTUPDATES                     # Enable FFS soft updates support
options         UFS_ACL                         # Support for access control lists
options         UFS_DIRHASH                     # Improve performance on big directories
options         UFS_GJOURNAL            # Enable gjournal-based UFS journaling
options         QUOTA                           # Enable disk quotas for UFS
options         MD_ROOT                         # MD is a potential root device
options         NFSCL                           # New Network Filesystem Client
options         NFSD                            # New Network Filesystem Server
options         NFSLOCKD                        # Network Lock Manager
options         NFS_ROOT                        # NFS usable as /, requires NFSCL
options         MSDOSFS                         # MSDOS Filesystem
options         CD9660                          # ISO 9660 Filesystem
options         PROCFS                          # Process filesystem (requires PSEUDOFS)
options         PSEUDOFS                        # Pseudo-filesystem framework
options         GEOM_PART_GPT           # GUID Partition Tables.
options         GEOM_RAID                       # Soft RAID functionality.
options         GEOM_LABEL                      # Provides labelization
options         COMPAT_FREEBSD32        # Compatible with i386 binaries
options         COMPAT_FREEBSD4         # Compatible with FreeBSD4
options         COMPAT_FREEBSD5         # Compatible with FreeBSD5
options         COMPAT_FREEBSD6         # Compatible with FreeBSD6
options         COMPAT_FREEBSD7         # Compatible with FreeBSD7
options         SCSI_DELAY=5000         # Delay (in ms) before probing SCSI
options         KTRACE                          # ktrace(1) support
options         STACK                           # stack(9) support
options         SYSVSHM                         # SYSV-style shared memory
options         SYSVMSG                         # SYSV-style message queues
options         SYSVSEM                         # SYSV-style semaphores
options         _KPOSIX_PRIORITY_SCHEDULING # POSIX P1003_1B real-time extensions
options         PRINTF_BUFR_SIZE=128            # Prevent printf output being interspersed.
options         KBD_INSTALL_CDEV        # install a CDEV entry in /dev
options         HWPMC_HOOKS                     # Necessary kernel hooks for hwpmc(4)
options         AUDIT                           # Security event auditing
options         CAPABILITY_MODE         # Capsicum capability mode
options         CAPABILITIES            # Capsicum capabilities
options         PROCDESC                        # Support for process descriptors
options         MAC                                     # TrustedBSD MAC Framework
options         KDTRACE_FRAME           # Ensure frames are compiled in
options         KDTRACE_HOOKS           # Kernel DTrace hooks
options         DDB_CTF                         # Kernel ELF linker loads CTF data
options         INCLUDE_CONFIG_FILE     # Include this file in kernel
# Debugging support.  Always need this:
options         KDB                              # Enable kernel debugger support.
options         KDB_TRACE                # Print a stack trace for a panic.
include OPTIONS
# Make an SMP-capable kernel by default
options         SMP                     # Symmetric MultiProcessor Kernel
# CPU frequency control
device          cpufreq
# Bus support.
device          acpi
device          pci
# Floppy drives
device          fdc
# ATA controllers
device          ahci                    # AHCI-compatible SATA controllers
device          ata                             # Legacy ATA/SATA controllers
options         ATA_STATIC_ID   # Static device numbering
device          mvs                             # Marvell 88SX50XX/88SX60XX/88SX70XX/SoC SATA
device          siis                    # SiliconImage SiI3124/SiI3132/SiI3531 SATA
# SCSI Controllers
device          ahc             # AHA2940 and onboard AIC7xxx devices
options         AHC_REG_PRETTY_PRINT    # Print register bitfields in debug
                                        # output.  Adds ~128k to driver.
device          ahd             # AHA39320/29320 and onboard AIC79xx devices
options         AHD_REG_PRETTY_PRINT    # Print register bitfields in debug
                                        # output.  Adds ~215k to driver.
device          esp             # AMD Am53C974 (Tekram DC-390(T))
device          hptiop          # Highpoint RocketRaid 3xxx series
device          isp                     # Qlogic family
#device         ispfw           # Firmware for QLogic HBAs- normally a module
device          mpt                     # LSI-Logic MPT-Fusion
device          mps                     # LSI-Logic MPT-Fusion 2
#device         ncr                     # NCR/Symbios Logic
device          sym                     # NCR/Symbios Logic (newer chipsets + those of `ncr')
device          trm                     # Tekram DC395U/UW/F DC315U adapters
device          adv                     # Advansys SCSI adapters
device          adw                     # Advansys wide SCSI adapters
device          aic                     # Adaptec 15[012]x SCSI adapters, AIC-6[23]60.
device          bt                      # Buslogic/Mylex MultiMaster SCSI adapters
device          isci            # Intel C600 SAS controller
# ATA/SCSI peripherals
device          scbus           # SCSI bus (required for ATA/SCSI)
device          ch                      # SCSI media changers
device          da                      # Direct Access (disks)
device          sa                      # Sequential Access (tape etc)
device          cd                      # CD
device          pass            # Passthrough device (direct ATA/SCSI access)
device          ses                     # Enclosure Services (SES and SAF-TE)
#device         ctl                     # CAM Target Layer
# RAID controllers interfaced to the SCSI subsystem
device          amr                     # AMI MegaRAID
device          arcmsr          # Areca SATA II RAID
#XXX it is not 64-bit clean, -scottl
#device         asr                     # DPT SmartRAID V, VI and Adaptec SCSI RAID
device          ciss            # Compaq Smart RAID 5*
device          dpt                     # DPT Smartcache III, IV - See NOTES for options
device          hptmv           # Highpoint RocketRAID 182x
device          hptnr           # Highpoint DC7280, R750
device          hptrr           # Highpoint RocketRAID 17xx, 22xx, 23xx, 25xx
device          hpt27xx         # Highpoint RocketRAID 27xx
device          iir                     # Intel Integrated RAID
device          ips                     # IBM (Adaptec) ServeRAID
device          mly                     # Mylex AcceleRAID/eXtremeRAID
device          twa                     # 3ware 9000 series PATA/SATA RAID
device          tws                     # LSI 3ware 9750 SATA+SAS 6Gb/s RAID controller
# RAID controllers
device          aac                     # Adaptec FSA RAID
device          aacp            # SCSI passthrough for aac (requires CAM)
device          aacraid         # Adaptec by PMC RAID
device          ida                     # Compaq Smart RAID
device          mfi                     # LSI MegaRAID SAS
device          mlx                     # Mylex DAC960 family
#XXX pointer/int warnings
#device         pst                     # Promise Supertrak SX6000
device          twe                     # 3ware ATA RAID
# atkbdc0 controls both the keyboard and the PS/2 mouse
device          atkbdc          # AT keyboard controller
device          atkbd           # AT keyboard
device          psm                     # PS/2 mouse
device          kbdmux          # keyboard multiplexer
device          vga                     # VGA video card driver
options         VESA            # Add support for VESA BIOS Extensions (VBE)
device          splash          # Splash screen and screen saver support
# syscons is the default console driver, resembling an SCO console
device          sc
options         SC_PIXEL_MODE   # add support for the raster text mode
device          agp                             # support several AGP chipsets
# PCCARD (PCMCIA) support
# PCMCIA and cardbus bridge support
#device         cbb                     # cardbus (yenta) bridge
#device         pccard          # PC Card (16-bit) bus
device          cardbus         # CardBus (32-bit) bus
# Serial (COM) ports
device          uart            # Generic UART driver
# Parallel port
device          ppc
device          ppbus   # Parallel port bus (required)
device          lpt             # Printer
device          ppi             # Parallel port interface device
#device         vpo             # Requires scbus and da
device          puc             # Multi I/O cards and multi-channel UARTs
# PCI Ethernet NICs.
device          bxe             # Broadcom NetXtreme II BCM5771X/BCM578XX 10GbE
device          de              # DEC/Intel DC21x4x (``Tulip'')
device          em              # Intel PRO/1000 Gigabit Ethernet Family
device          igb             # Intel PRO/1000 PCIE Server Gigabit Family
device          ixgbe   # Intel PRO/10GbE PCIE Ethernet Family
device          le              # AMD Am7900 LANCE and Am79C9xx PCnet
device          ti              # Alteon Networks Tigon I/II gigabit Ethernet
device          txp             # 3Com 3cR990 (``Typhoon'')
device          vx              # 3Com 3c590, 3c595 (``Vortex'')
# PCI Ethernet NICs that use the common MII bus controller code.
# NOTE: Be sure to keep the 'device miibus' line in order to use these NICs!
#device         miibus          # MII bus support
#device         ae              # Attansic/Atheros L2 FastEthernet
#device         age             # Attansic/Atheros L1 Gigabit Ethernet
#device         alc             # Atheros AR8131/AR8132 Ethernet
#device         ale             # Atheros AR8121/AR8113/AR8114 Ethernet
#device         bce             # Broadcom BCM5706/BCM5708 Gigabit Ethernet
#device         bfe             # Broadcom BCM440x 10/100 Ethernet
#device         bge             # Broadcom BCM570xx Gigabit Ethernet
#device         cas             # Sun Cassini/Cassini+ and NS DP83065 Saturn
#device         dc              # DEC/Intel 21143 and various workalikes
#device         et              # Agere ET1310 10/100/Gigabit Ethernet
#device         fxp             # Intel EtherExpress PRO/100B (82557, 82558)
#device         gem             # Sun GEM/Sun ERI/Apple GMAC
#device         hme             # Sun HME (Happy Meal Ethernet)
#device         jme             # JMicron JMC250 Gigabit/JMC260 Fast Ethernet
#device         lge             # Level 1 LXT1001 gigabit Ethernet
#device         msk             # Marvell/SysKonnect Yukon II Gigabit Ethernet
#device         nfe             # nVidia nForce MCP on-board Ethernet
#device         nge             # NatSemi DP83820 gigabit Ethernet
#device         nve             # nVidia nForce MCP on-board Ethernet Networking
#device         pcn             # AMD Am79C97x PCI 10/100 (precedence over 'le')
#device         re              # RealTek 8139C+/8169/8169S/8110S
#device         rl              # RealTek 8129/8139
#device         sf              # Adaptec AIC-6915 (``Starfire'')
#device         sge             # Silicon Integrated Systems SiS190/191
#device         sis             # Silicon Integrated Systems SiS 900/SiS 7016
#device         sk              # SysKonnect SK-984x & SK-982x gigabit Ethernet
#device         ste             # Sundance ST201 (D-Link DFE-550TX)
#device         stge    # Sundance/Tamarack TC9021 gigabit Ethernet
#device         tl              # Texas Instruments ThunderLAN
#device         tx              # SMC EtherPower II (83c170 ``EPIC'')
#device         vge             # VIA VT612x gigabit Ethernet
#device         vr              # VIA Rhine, Rhine II
#device         wb              # Winbond W89C840F
#device         xl              # 3Com 3c90x (``Boomerang'', ``Cyclone'')
# ISA Ethernet NICs.  pccard NICs included.
#device         cs              # Crystal Semiconductor CS89x0 NIC
# 'device ed' requires 'device miibus'
#device         ed              # NE[12]000, SMC Ultra, 3c503, DS8390 cards
#device         ex              # Intel EtherExpress Pro/10 and Pro/10+
#device         ep              # Etherlink III based cards
#device         fe              # Fujitsu MB8696x based cards
#device         sn              # SMC's 9000 series of Ethernet chips
#device         xe              # Xircom pccard Ethernet
# Wireless NIC cards
device          wlan                    # 802.11 support
options         IEEE80211_DEBUG # enable debug msgs
options         IEEE80211_AMPDU_AGE # age frames in AMPDU reorder q's
options         IEEE80211_SUPPORT_MESH  # enable 802.11s draft support
device          wlan_wep                # 802.11 WEP support
device          wlan_ccmp               # 802.11 CCMP support
device          wlan_tkip               # 802.11 TKIP support
device          wlan_amrr               # AMRR transmit rate control algorithm
device          an                              # Aironet 4500/4800 802.11 wireless NICs.
device          ath                             # Atheros NICs
device          ath_pci                 # Atheros pci/cardbus glue
device          ath_hal                 # pci/cardbus chip support
options         AH_SUPPORT_AR5416       # enable AR5416 tx/rx descriptors
options         AH_AR5416_INTERRUPT_MITIGATION  # AR5416 interrupt mitigation
options         ATH_ENABLE_11N  # Enable 802.11n support for AR5416 and later
device          ath_rate_sample # SampleRate tx rate control for ath
#device         bwi                             # Broadcom BCM430x/BCM431x wireless NICs.
#device         bwn                             # Broadcom BCM43xx wireless NICs.
device          ipw                             # Intel 2100 wireless NICs.
device          iwi                             # Intel 2200BG/2225BG/2915ABG wireless NICs.
device          iwn                             # Intel 4965/1000/5000/6000 wireless NICs.
device          malo                    # Marvell Libertas wireless NICs.
device          mwl                             # Marvell 88W8363 802.11n wireless NICs.
device          ral                             # Ralink Technology RT2500 wireless NICs.
device          wi                              # WaveLAN/Intersil/Symbol 802.11 wireless NICs.
device          wpi                             # Intel 3945ABG wireless NICs.
# Pseudo devices.
device          loop            # Network loopback
device          random          # Entropy device
device          padlock_rng     # VIA Padlock RNG
device          rdrand_rng      # Intel Bull Mountain RNG
device          ether           # Ethernet support
device          vlan            # 802.1Q VLAN support
device          tun                     # Packet tunnel.
device          md                      # Memory "disks"
device          gif                     # IPv6 and IPv4 tunneling
device          faith           # IPv6-to-IPv4 relaying (translation)
device          firmware        # firmware assist module
# The `bpf' device enables the Berkeley Packet Filter.
# Be aware of the administrative consequences of enabling this!
# Note that 'bpf' is required for DHCP.
device          bpf                     # Berkeley packet filter
# USB support
options         USB_DEBUG       # enable debug msgs
device          uhci            # UHCI PCI->USB interface
device          ohci            # OHCI PCI->USB interface
device          ehci            # EHCI PCI->USB interface (USB 2.0)
device          xhci            # XHCI PCI->USB interface (USB 3.0)
device          usb             # USB Bus (required)
device          ukbd            # Keyboard
device          umass           # Disks/Mass storage - Requires scbus and da
# Sound support
device          sound           # Generic sound driver (required)
#device         snd_cmi         # CMedia CMI8338/CMI8738
#device         snd_csa         # Crystal Semiconductor CS461x/428x
#device         snd_emu10kx     # Creative SoundBlaster Live! and Audigy
#device         snd_es137x      # Ensoniq AudioPCI ES137x
device          snd_hda         # Intel High Definition Audio
#device         snd_ich         # Intel, NVidia and other ICH AC'97 Audio
#device         snd_via8233     # VIA VT8233x Audio
# MMC/SD
device          mmc             # MMC/SD bus
device          mmcsd           # MMC/SD memory card
device          sdhci           # Generic PCI SD Host Controller
# VirtIO support
device          virtio          # Generic VirtIO bus (required)
device          virtio_pci      # VirtIO PCI device
device          vtnet           # VirtIO Ethernet device
device          virtio_blk      # VirtIO Block device
device          virtio_scsi     # VirtIO SCSI device
device          virtio_balloon  # VirtIO Memory Balloon device
# HyperV drivers
##device                hyperv          # HyperV drivers
# Xen HVM Guest Optimizations
# NOTE: XENHVM depends on xenpci.  They must be added or removed together.
options         XENHVM          # Xen HVM kernel infrastructure
device          xenpci          # Xen HVM Hypervisor services driver
# VMware support
# device                vmx             # VMware VMXNET3 Ethernet
/usr/src/sys/amd64/conf/OPTIONS
device carp
############# IPFW #################
options         IPFIREWALL
options         IPFIREWALL_VERBOSE
options         IPFIREWALL_VERBOSE_LIMIT=10
options         IPFIREWALL_NAT
options         IPDIVERT
options         LIBALIAS
options         ROUTETABLES=2
options         DUMMYNET
options         ACCEPT_FILTER_HTTP
options         ACCEPT_FILTER_DATA
####### SMB ########
options         NETSMB                  #SMB/CIFS requester
#options        NETSMBCRYPTO            #encrypted password support for SMB
options         LIBMCHAIN               #mbuf management library
options         LIBICONV
options         SMBFS
# Disable reboot on Ctrl Alt Del
options         SC_DISABLE_REBOOT
# Change normal|kernel messages color
options         SC_NORM_ATTR=(FG_GREEN|BG_BLACK)
options         SC_KERNEL_CONS_ATTR=(FG_YELLOW|BG_BLACK)
options         SC_NORM_REV_ATTR=(FG_YELLOW|BG_GREEN)
options         SC_KERNEL_CONS_REV_ATTR=(FG_BLACK|BG_RED)
# More scroll space
options SC_HISTORY_SIZE=8192
# UTF-8
#options TEKEN_UTF8
options        VGA_WIDTH90
options DEVICE_POLLING
#### netgraph options ####
options HZ=1000
options NETGRAPH
options NETGRAPH_PPPOE
options NETGRAPH_SOCKET
options NETGRAPH_CISCO
options NETGRAPH_ECHO
options NETGRAPH_FRAME_RELAY
options NETGRAPH_HOLE
options NETGRAPH_KSOCKET
options NETGRAPH_LMI
options NETGRAPH_RFC1490
options NETGRAPH_TTY
options NETGRAPH_ASYNC
options NETGRAPH_BPF
options NETGRAPH_ETHER
options NETGRAPH_IFACE
options NETGRAPH_L2TP
options NETGRAPH_MPPC_ENCRYPTION
options NETGRAPH_PPTPGRE
options NETGRAPH_TEE
options NETGRAPH_UI
options NETGRAPH_VJC
 /etc/rc.conf
### SCREEN MODE ###
#allscreens_flags="MODE_324"
### ZFS ###
zfs_enable="YES"
### Suppart linux ###
linux_enable="YES"
### Name of host ###
hostname="srv"
### RUS & mouse ###
font8x14="cp866-8x14"
font8x16="cp866-8x16"
font8x8="cp866-8x8"
scrnmap="koi8-r2cp866"
keymap="ru.koi8-r.win.kbd"
moused_enable="YES"
### Screen Saver ###
# beastie green blank logo daemon rain dragon snake fade star fire warp
saver="beastie"      # screen saver: Uses /boot/kernel/${saver}_saver.ko
blanktime="100"
### NETWORK ###
ifconfig_em0="inet 195.0.1.1 netmask 255.255.255.0"
ifconfig_em1="inet 192.168.1.1 netmask 255.255.255.0"
defaultrouter="195.0.1.2"
# ===== NETWORK SERVICES ===== #
### IPFW ###
firewall_enable="YES"
firewall_script="/usr/local/etc/rc.d/ipfw.sh"
firewall_type="SIMPLE"
firewall_quiet="NO"
### NAT ###
firewall_nat_enable="YES"
firewall_flags="unreg_only same_ports reset"
firewall_nat_interface="em0"
dummynet_enable="YES"
### gateway ###
gateway_enable="YES"
### Time Server  ###
ntpd_enable="YES"
ntpd_sync_on_start="YES"
### SSH  ###
sshd_enable="YES"
### WEB SERVER ###
apache24_enable="YES"
### DataBase Server ###
mysql_enable="YES"
### DHCP SERVER  ###
dhcpd_enable="YES"
### UCARP ####
ucarp_enable="YES"
ucarp_vhid="1"
ucarp_if="em1"
ucarp_src="192.168.1.1"
ucarp_addr="192.168.1.254"
# ucarp_advskew="50"
# ucarp_preempt="YES" # For always use master with lover advskew
ucarp_pass="secret"
ucarp_upscript="/usr/local/etc/vip-up.sh"
ucarp_downscript="/usr/local/etc/vip-down.sh"
###clear tmp###
clear_tmp_enable="YES"
dumpdev="NO"
#!/bin/sh
# Объявляем переменные
IpFw="/sbin/ipfw -q"          # бинарник IPFW
LanOut="em0"                  # Внешняя сетевуха
LanIn="em1"                   # внутренняя сетевуха
IpOut="195.0.1.1"             # Внешний IP
NetOut="195.0.1.0/24"         # внешняя сеть
NetIn="192.168.1.0/24"        # Внутренняя сеть
Ip_Lan="192.168.1."           # Шаблон внутреннего адреса нужен для ввода разрешений на инет
Vpn_Lan="15.15.15.0/24{50-99}"
# список ip серверов времени и при необходимости внешняя сеть для отачи времени
ntp="{ 212.1.224.6 or 212.1.244.6 or 195.0.1.0/24 }"
dns="{ 195.0.1.3 or 195.0.1.2 }" #список ip днс провайдера
# Чистим старые правила, очереди перед обновлением правил
${IpFw} -f flush
${IpFw} -f pipe  flush
${IpFw} -f queue flush
# Позволяем пакету проходить, если предыдущий был добавлен
# в "динамическую" таблицу правил с разрешением состояния keep-state.
${IpFw} add check-state
# Пример разрешения SSH-трафика с определённого хоста
${IpFw} add allow tcp from 195.0.1.8 to me 22 in via ${LanOut} setup keep-state
${IpFw} add allow tcp from me to 195.0.1.8 22 out via ${LanOut} setup keep-state
# Разрешить прохождение любых пакетов с адреса админской машины
${IpFw} add allow tcp from 195.0.1.3 to me in via ${LanOut} setup keep-state
# Разрешить прохождение любых пакетов на адрес админской машины
#${IpFw} add 100 allow tcp from me to 195.0.1.3 out via ${LanOut} setup keep-state
# NAT
${IpFw} nat 1 config ip ${IpOut} log
${IpFw} add nat 1 ip from 192.168.1.0/24 to any out via ${LanOut}
${IpFw} add nat 1 ip from any to ${IpOut} in via ${LanOut}
### Запрет фрагментирванных пакетов
${IpFw} add deny log all from any to any frag
# Запрещаем ACK пакеты которые не совпадают с динамической таблицей правил
${IpFw} add deny log tcp from any to any established in via ${LanOut}
## Запрещаем принимать на lo0 и отправлять с lo0 пакеты с иных интерфейсов
${IpFw} add deny log all from 0.0.0.0/8 to any in via ${LanOut}    #loopback
${IpFw} add deny log ip from any to 127.0.0.0/8 in via ${LanOut}
${IpFw} add deny log ip from 127.0.0.0/8 to any out via ${LanOut}
# Запретить принимать пакеты из частных сетей внешним интерфейсом из инета
${IpFw} add deny log ip from any to 10.0.0.0/8 via ${LanOut}
${IpFw} add deny log ip from any to 172.16.0.0/12 via ${LanOut}
${IpFw} add deny log ip from any to 192.168.0.0/16 via ${LanOut}
# Запрет мультикаста на интернет интерфейсе
${IpFw} add deny log ip from any to 240.0.0.0/4 in via ${LanOut}
${IpFw} add deny log ip from 224.0.0.0/4 to any out via ${LanOut}
# Запрет частной сети MS на интернет интерфейсе
${IpFw} add deny log ip from any to 169.254.0.0/16 in via ${LanOut}
${IpFw} add deny log ip from 169.254.0.0/16 to any out via ${LanOut}
${IpFw} add deny log all from 192.0.2.0/24 to any in via ${LanOut}   #reserved for docs
${IpFw} add deny log all from 204.152.64.0/23 to any in via ${LanOut} #Sun cluster interconnect
# Запрещаем весь сервис Netbios. 137=имя, 138=дейтаграмма, 139=сессия
# Netbios это сервис общего доступа MS/Windows. Блокируем MS/Windows hosts2 name server requests 81
${IpFw} add deny log tcp from any to any 137 via ${LanOut}
${IpFw} add deny log tcp from any to any 138 via ${LanOut}
${IpFw} add deny log tcp from any to any 139 via ${LanOut}
${IpFw} add deny log tcp from any to any 81 via ${LanOut}
### Запрещаем ident
${IpFw} add deny log tcp from any to any 113 via ${LanOut}
### разрешаем пакеты на интерфейсе lo0
${IpFw} add allow ip from any to any via lo0
### NTP ТРАФИК
${IpFw} add allow udp from any to ${ntp} 123
${IpFw} add allow udp from ${ntp} to any 123
### DNS ТРАФИК
${IpFw} add allow udp from me to ${dns} 53 out via ${LanOut}
${IpFw} add allow tcp from me to ${dns} 53 out via ${LanOut} setup keep-state
# Разрешить трафик в интернет
# setup - Это обязательное ключевое слово определяет начало запроса сессии для TCP пакетов.
# keep-state - Это обязательное ключевое слово. При совпадении межсетевой экран создает
# динамическое правило, которое по умолчанию будет совпадать с двунаправленным трафиком
# между отправителем и получателем для данной пары IP/порт по указанному протоколу.
${IpFw} add allow tcp from me to any 20 out via ${LanOut} setup keep-state
${IpFw} add allow tcp from me to any 21 out via ${LanOut} setup keep-state
${IpFw} add allow tcp from me to any 80 out via ${LanOut} setup keep-state
${IpFw} add allow tcp from me to any 443 out via ${LanOut} setup keep-state
${IpFw} add allow tcp from me to any 1024-65535 out via ${LanOut} setup keep-state
### VPN
${IpFw} add allow tcp from any to me dst-port 1723 setup keep-state
${IpFw} add allow gre from any to me
${IpFw} add allow gre from me to any
# Traceroute может работать используя udp или icmp протокол.
# Для udp:
${IpFw} add allow udp from any to any 33434-33625 out via ${LanOut} keep-state
# Traceroute на icmp нудны следующие типы (0,3,4,8,11,12)
# PING
#  0 - Эхо-ответ (Echo Replay)
#  3 - Узел назначения недостижим (Destination Unreachable)
#  4 - Подавление источника (Source Quench)
#  5 - Перенаправление маршрута (Redirect)
#  8 - Эхо-запрос (Echo Request)
# 11 - Истечение времени дейтаграммы (Time Exceeded for a Datagram)
# 12 - Проблема с параметром пакета (Parameter Problem on a Datagram)
${IpFw} add allow icmp from ${NetOut} to me icmptype 0,3,4,5,8,11,12 in via ${LanOut} keep-state
${IpFw} add allow icmp from me to ${NetOut} icmptype 0,3,4,5,8,11,12 out via ${LanOut} keep-state
# --- РАЗРЕШАЕМ ПОЛЬЗОВАТЕЛЯМ ВЫХОД В ИНЕТ --- #
${IpFw} add allow all from 192.168.1.0/24 to any
${IpFw} add allow all from any to 192.168.1.0/24
printf "\n#################################\n# RULES LOADED. FIREWALL WORKS! # \n#################################\n"
 /etc/ntp.conf
server 212.1.224.6 prefer
server 212.1.244.6
# restrict default nomodify notrap nopeer noquery
restrict 212.1.224.6
restrict 212.1.244.6
restrict 127.0.0.1
restrict 192.168.1.0 mask 255.255.255.0 nomodify notrap
restrict 195.0.1.0 mask 255.255.255.0 nomodify notrap
server 127.127.1.0
fudge 127.127.1.0 stratum 5
driftfile /etc/ntp.drift
logfile /var/log/ntp.log # Основной лог
 /etc/resolv.conf
search serg.ru test.ru
# Время ожидания ответа от сервера имён
option timeout:1
# Список адресов DNS-серверов
nameserver 195.0.1.3
nameserver 195.0.1.2
 /etc/hosts
#::1                    localhost localhost.serg.ru
127.0.0.1               localhost localhost.serg.ru
195.0.1.1              srv.serg.ru srv
192.168.1.1            gate1.test.ru gate1
195.0.1.8              srv92.serg.ru srv92
192.168.1.2            gate2.test.ru gate2
# для машины админа, чтобы SSH не тормазил при проблемах с DNS
195.0.1.3              sergey.serg.ru sergey
Создать файл  /usr/local/etc/apache24/Includes/php.conf
<FilesMatch "\.php$">
    SetHandler application/x-httpd-php
</FilesMatch>
<FilesMatch "\.phps$">
    SetHandler application/x-httpd-php-source
</FilesMatch>
AddType application/x-httpd-php .php
AddType application/x-httpd-php-source .phps
 /usr/local/etc/php/extensions.ini
Если не запускается Apache после сборки PHP 5.5.14. то нужно закомментировать запуск модуля recode
;extension=recode.so
 ~/.my.cnf
[mysql]
password = 123456
# Отключает автоматическое рехеширование. rehash следует использовать для получения
# хеша таблиц и полей. Это обеспечивает более быстрый старт mysql.
no-auto-rehash
#connect_timeout=2
pager = less -n -i -S
prompt =(\u@\h) [\d]>
[mysqlhotcopy]
interactive-timeout
 UCARP
cat /usr/local/etc/vip-up.sh
#!/bin/sh
ifconfig em1 inet 192.168.1.254/32 alias
#!/bin/sh
ifconfig em1 inet 192.168.1.254/32 -alias
 /usr/local/etc/proftpd.conf
# For more information about Proftpd configuration
# see http://www.proftpd.org/
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use.  It establishes a single server
# and a single anonymous login.  It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName                      "ProFTPD on FreeBsd v11"
ServerType                      standalone
# Привязка к интерфейсу
#DefaultServer                  on
SocketBindTight on
DefaultAddress em0
ScoreboardFile                  /var/run/proftpd/proftpd.scoreboard
# Port 21 is the standard FTP port.
Port                            21
# Use IPv6 support by default.
#UseIPv6                                off
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask                           022
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances                    30
CommandBufferSize               512
# Set the user and group under which the server will run.
User                            nobody
Group                           nogroup
# Normally, we want files to be overwriteable.
AllowOverwrite                  on
# Без этой опции proftpd сваливается с ошибкойalarm clock
ScoreboardScrub                 off
DebugLevel 9
LogFormat                       default "%h %l %u %t \"%r\" %s %b"
LogFormat                       auth    "%v [%P] %h %t \"%r\" %s"
LogFormat                       write   "%h %l %u %t \"%r\" %s %b"
SystemLog                       /var/log/proftpd/proftpd.log
TransferLog                     /var/log/proftpd/xfer.log
ExtendedLog                     /var/log/proftpd/access.log WRITE,READ write
ExtendedLog                     /var/log/proftpd/auth.log AUTH auth
<Global>
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
# Если нужно сделать исключение из правил и дать
# некоторым пользователям полный доступ, то создаете группу, например admins
# и пишете
# DefaultRoot ~ !admins
  DefaultRoot ~
  PassivePorts                  40000 45535
  AuthUserFile                  /usr/local/etc/proftpd/ftpd.passwd
# RequireValidShell             off
  LangEngine                    on
  UseEncoding                   UTF-8 WINDOWS-1251
</Global>
LangPath                        /usr/share/locale
AuthOrder                       mod_auth_file.c
LoadModule                      mod_tls.c
TLSEngine                       on
TLSLog                          /var/log/proftpd/tls.log
TLSProtocol                     SSLv23
TLSRequired                     auth
TLSOptions                      NoCertRequest
TLSRSACertificateFile           /usr/local/etc/proftpd/cert.pem
TLSRSACertificateKeyFile        /usr/local/etc/proftpd/key.pem
TLSVerifyClient                 off
# Bar use of SITE CHMOD by default
<Limit SITE_CHMOD>
  DenyAll
</Limit>
# A basic anonymous configuration, no upload directories.  If you do not
# want anonymous users, simply delete this entire <Anonymous> section.
<Directory /usr/home/~>
Umask 022 022
<Limit READ WRITE STOR>
        AllowAll
        </Limit>
</Directory>
# Uncomment lines with only one # to allow basic anonymous access       #
#<Anonymous ~ftp>
#   User                                ftp
#   Group                               ftp
  ### We want clients to be able to login with "anonymous" as well as "ftp"
  # UserAlias                   anonymous ftp
  ### Limit the maximum number of anonymous logins
  # MaxClients                  10
  ### We want 'welcome.msg' displayed at login, and '.message' displayed
  ### in each newly chdired directory.
  # DisplayLogin                        welcome.msg
  # DisplayFirstChdir           .message
  ### Limit WRITE everywhere in the anonymous chroot
  # <Limit WRITE>
  #   DenyAll
  # </Limit>
#</Anonymous>
И создаём ключи
openssl req -new -x509 -days 720 -nodes -out /usr/local/etc/proftpd/cert.pem -keyout /usr/local/etc/proftpd/key.pem
 12
 13
 14
 15
 16
 17
